Do you know how to adjust the focus, if yes, you can just buy the lens, if not, better to buy the lens with sensor board, it will cost more if buy the sensor board together.Hey just crashed the quad and the lens got a micro scratch. nothing serious at all but i wanted to know what the options are on replacing the lens. anyone know where i can find spares?
you are awesome! thank you very much for the help!!! ill pm you when I'm in needDo you know how to adjust the focus, if yes, you can just buy the lens, if not, better to buy the lens with sensor board, it will cost more if buy the sensor board together.
If you want to buy one, please drop a PM to me.
Better use hot plastic glue (silicone). Teflon tape will not be secure enough, also avoid superglue at all cost, it has vapors that will glaze the lens.some secure the lens with teflon tape but I don t know if it is as good .
Does there is more than 2 lens option???
It's in final editing, almost done, it may me possible that I post it later today or tomorrow.Did you create a video / instructions on how to replace the lens/sensor board? I might like to try the 90 degree lens?
Yuk! Yuk!Gitup might also sell you their 90 degree narrow FOV lens to make it easier to see what you are about to hit!
Question about the 90 FOV lens.
Is that a factory unit with the sensor and lens, pre (or fixed) focus from factory, locked in place by glue ?
So installing it is just a matter of picking the gitup2 apart replacing the part and putting it back together ?
Why are there no units from factory with this narrow lens or is the demand (market) just to small for that ?
The sample recorded with the 4.35mm lens.I've spotted the new 4.35mm lens on the store this morning. Are there any video samples that show performance? Considering one of the extra lenses with my order. Thanks!
