Julian Warr
- Mar 22, 2015
- United Kingdom
Hi All
I hope you can help or advise me accordingly. I am based in UK and after much research I purchased a Mini 0806 from GearBest in March, but have only been using it in the last 12 days (as my car was in the garage until then). I have had some issues within that period of time.
Firstly there was no GPS - This has been rectified after discovering the GPS wire was broken and a longer wire was fitted. All good again.
Now twice in the last week, the camera has completely frozen, with the red power light on continuously, I have managed to get it back by letting the battery run out. Each time, the only setting that has been reset is the time & date, every other setting is ok. But...I think the camera may have done something to the SD cards as I cannot format them (from PC or 0806) or remove files from them etc as it stated the disk is write protected. I can view the recorded files on 0806 but cannot delete them, and they are not protected (no little lock symbol by thumbnails)
I have tried everything from 'diskpart in dos' , Regedit to EaseUS partition master, plus a few others and I cannot get rid of the files, thus I have 2 new SD cards that are useless.
Is this a known issue? should I be looking to return the device (loathed to as it is in China and very inconvenient and expensive to do)? Can it be solved? I am also wondering whether this only happens when the card becomes full and it attempts to loop the recordings, but I have no way to test this, without buying another SD card (and that is not happening)
I really like the camera, but its getting a little tedious waiting for the next thing to go wrong with it.
Any help or advice would be gratefully received
J
PS I am using the camera rotated 180 degrees (I know from checking the forums there were other issues with that)
J
