fmendessilva
- Jan 22, 2019
- Portugal
Hi. I cannot connect the GPS module. I followed all the steps in manual but I am always getting message "GPS module not connected". Any suggestion? Regards
But how do I do this? I went to the app and entered int "advanced settings" > ADAS to enable this option but I get the message "GPS module not connected". I am sure the GPS mount holder is fitting good.You have to enable the GPS module in settings in the app. Until you do that, it's disabled.
I have a similar problem, but I figured out that when slight pressure is applied to the screen it works. I guess something is wrong with the connectors. Hope this info will help you.Hi. I cannot connect the GPS module. I followed all the steps in manual but I am always getting message "GPS module not connected". Any suggestion? Regards
Thanks for your help. I will try again. I hope it works. Regards from Portugal!I have a similar problem, but I figured out that when slight pressure is applied to the screen it works. I guess something is wrong with the connectors. Hope this info will help you.
Hi. My one also got the same problem.Problem solved. View attachment 53028
I bought it yesterday and everything fine till just now when I afterwork go home only notice this problem. I need to press and hold it only can detect.... 1 day only and got problem....
So you open the shell and it work? Then how u stick back the your windscreen?
Currently i try to talk with the Shopee seller 1st, c what they say, if they dun want replace or anything.Our weather is too hot bro.
It's design flaw and you have to make sure the PCB stick firmly on the back cover. Apply new double sided tape on your windscreen and voila!
Do take note this will void the warranty if you plan to claim for a new replacement.
Then i only try to like what u did.
But is very sad, just 1 day, now stop workin T_T
