i have push reset but my dashcam have not still power on yet.... i dont have file .ELF and only have file.bin ..... where i can find file firmware .ELF?jokiin said:Power button won't work until you push the reset switch, did you do that?
HDCAM.VN said:i have push reset but my dashcam have not still power on yet.... i dont have file .ELF and only have file.bin ..... where i can find file firmware .ELF?jokiin said:Power button won't work until you push the reset switch, did you do that?
my seller send me file .bin .... i can update firware by driver usb with file.bin?jokiin said:HDCAM.VN said:i have push reset but my dashcam have not still power on yet.... i dont have file .ELF and only have file.bin ..... where i can find file firmware .ELF?jokiin said:Power button won't work until you push the reset switch, did you do that?
the manufacturer of your cam would have it, check with who you purchased from to see if you can get it, these things are very hard to brick so providing you can get the correct firmware you should be able to get it going, suggest not trying random firmware versions from lookalike cams in future, they are not all created equally
HDCAM.VN said:my seller send me file .bin .... i can update firware by driver usb with file.bin?
where do i know gs5000 firmware .elf ?my last firmware gs5000 V2.0.4 G2KB i try with some file elf from http://dashcamtalk.com/gs1000/http://dashcamtalk.com/gs1000/ and driver usb note:suscess program ...but can not power on my dash cam ....jokiin said:HDCAM.VN said:my seller send me file .bin .... i can update firware by driver usb with file.bin?
he likely sent you the version that loads from memory card, if he has this though he should be able to get the elf version, the bin version you load from card is not the same as the bin version created when loading via elf using the USB method
HDCAM.VN said:where do i know gs5000 firmware .elf ?my last firmware gs5000 V2.0.4 G2KB i try with some file elf from http://dashcamtalk.com/gs1000/http://dashcamtalk.com/gs1000/ and driver usb note:suscess program ...but can not power on my dash cam ....jokiin said:HDCAM.VN said:my seller send me file .bin .... i can update firware by driver usb with file.bin?
GPS_v2.0.3SG1KB.elf
GPS_v1.1.1SG1KB.elf
