- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
Bit of an update for anyone that might be interested
Our tooling is nearing final stage (first injection test was today) which means possibly Friday we should be getting some of the first sample tooling, depending what fine adjustments are required, there's always something
We've made a couple of refinements to the design, power button was raised up slightly to make it easier to operate, took the red reference line off the back of the camera and changed it to black, we've added the location of the two LED's (power and record) that are next to the screen
Our patent paperwork has been filed so I can show a bit more detail than I wanted to previously
Here's the camera off the mount bracket
Here's the mount bracket, as mentioned previously the bracket stays attached to the window when you take the camera off and contains the 12v/24v power supply and the GPS is built into the bracket, power cable of course is connected to the bracket
We're another revision down on the mainboard and 2 revisions in on firmware, still stuff to be done though of course, most of the firmware stuff is sorted but still some fine tuning and as per the previous camera we'll continue working on it, adding features and improvements along the way
We've also been working on the accessories, nothing is off the shelf so just doing things like power cables, we're using an Apple MFI licensed supplier for the power adapter, not because it has anything to do with Apple but basically because the standard is higher, real copper wire, better quality fittings, that sort of thing, little stuff in the scheme of things but all things that need to be done, still lots to do, user manuals, accessories, packaging etc that will keep us (me) busy over the next few weeks
This first one is by far the most involved because everything is new, a lot of what we're doing though translates directly to the following models as there's a lot of shared hardware so the following models will be able to roll out much quicker than this one has, more on those models as we get closer
