- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
Yes we do hot keys to toggle .motion detect, we did it with our last product also
The power button realistically is not something you'd need to use too often but it just wasn't good enough so I changed it.
@ jokiin could the night mode not be a simple on/off in the wintertime it can be dark at 16.30 in the evening and still dark at 08.30 in the morning In the summer it can still be light at 23.00 ....Just a thought Ipol
we do have some long and short press shortcut menu options already, that's not detailed in the text but I'll elaborate on that once it's all done, not exactly as you've described but similar
That's great. Hope the mic on/off is one of the shortcuts as I can see that as something I would definitely use.
I can just see how making the long presses user configurable would really take the user experience of the unit to the next level.
interesting idea, not sure it's possible but I'll mention it to our engineer and see what he thinks
what kinds of things would you like to see as options?
@ jokiin Just realised my garmin gps automatically goes to night mode when the light falls to a certain level but this of course may well be a costly option............Ipol
first 4 are on the list already, remapping buttons I'd expect would be reasonably complex so not sure how practical that would be, could also add support issues, things like changing bitrate while recording won't happen, that would play havoc with recycling and a bunch of other things so I'm sure that would be out, from experience I can tell you that the greater majority of our customers run the cameras at the highest bitrate and leave them like that, day/night I want to automate as much as possible anyway, we're looking at some user configurable parameters for this though, things like changing EV and white balance I think are probably counter productive as you could unknowingly adjust things for the worse, those are settings you generally need to set, use, check and compare to decide what's bestThere is 11 options right there, no doubt other users will chime in with some others.
Wouldent it be possibel to use the cmos as i kind of light sensor ?
Trigger somthing when the ISO goes over a certain value.
What's the difference between Parking and Valet modes?
for perspective the camera width and height is slightly bigger than a credit card, while the power button may look large and prominent in the pictures, it's actually not that big, previously it was recessed slightly and it may have made it inconvenient to use
ThanksValet mode is just continue to do normal recording like when you are driving, only without any lights and LCD off. Basically no indication that the unit is working (so the valet driver does not know his driving is being recorded).
Parking mode is the usual, only record/save the footage after a g-sensor activation.
things like changing bitrate while recording won't happen ...... things like changing EV and white balance I think are probably counter productive as you could unknowingly adjust things for the worse, those are settings you generally need to set, use, check and compare to decide what's best
keep going though, you never know what's achievable if you don't ask![]()
