- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
It is strongly recommended to use the SD Memory Card Formatter to format SD/SDHC/SDXC Cards rather than using formatting tools provided with individual operating systems. In general, formatting tools provided with operating systems can format various storage media including SD/SDHC/SDXC Cards, but it may not be optimized for SD/SDHC/SDXC Cards and it may result in lower performance.
SDformatter can be downloaded here http://bit.ly/SDformatter
Aside from normal formatting you may have been advised to use SDformatter to do a full overwrite format of your memory card, doing this will check the entire card and return the memory card to its default state, it can take quite a while to complete but is often necessary to return a card to a working state (32GB cards can take around 1 hour to process depending on the card speed and the speed of your card reader, USB 3.0 readers are preferred where available)
The process to do a full overwrite is as follows (Windows version shown)
Download and install the SDformatter software, open the program and select the drive letter that matches your memory card, select the Overwrite format option
Once options are correct select Format
SDformatter will ask you confirm, select YES
While formatting the program will show the progress
Once complete the program will show the results
Process is complete, this will return the card to its default state, the card should be formatted in the camera before use
Note: if using a camera that does not support the formatting of cards larger than 32GB you may need to format using another tool prior to use, check with your camera manufacturer regarding the recommended program for formatting
EDIT: updated to show latest version of SDFormatter which has simplified the process
