Help upgrade or replace dashcam without changing wires
bmwx5
Calgary
So I purchased a cheap camera, and it stopped working.
I know some might say, why are you buying another cheap camera, it will happen again.
Unfortunately I really don't want to redo the wiring, so I already have the cables.
I installed the cables when my headliner and dashboard were removed, and the vehicle was pretty much stripped.
I can't just pull on the cable and feed a new wire in its place.
Without boring you with details, here's my problem.
My camera is powered by a connector called ubs Mini B.
This does not seem like a huge issue, there seems to be a lot of adapters.
The bigger issue, is the wire that goes to the rear camera in the trunk has a mini HDMI connector on the dashcam.
https://www.amazon.ca/gp/B083SLMBZM
Is seems that all these genetic cheap cameras change that cable, and instead on using mini hdmi connector, they're using 3.5mm aux jack.
So I'm wondering if there's any cameras left with hdmi mini port for the rear camera?
