Paul Schmehl
- Aug 7, 2016
- Richardson, TX
- Street Guardian SG9663DCPRO (front cam only)
Pretty much the same thing I do, but with a razor blade scraper - makes it easy to get started, just use a good blade so you don't scratch the glass.I ended up using a chisel. I put it up against the base and gently tapped with my hand, to get it started. Then I pried from side to side and worked it until it started peeling loose. Eventually it came off with very little residue left behind.
I started out with something like that, but the razorblade was so thin I was afraid I was going to break it. The chisel had enough oomph to work it loose.Pretty much the same thing I do, but with a razor blade scraper - makes it easy to get started, just use a good blade so you don't scratch the glass.
Something like this:
https://www.amazon.com/gp/B07MJTZM2Z
