country_hick
- Dec 10, 2014
I went through the dash cam comparison page. After looking for what I thought would be best I ended up with this list.
https://dashcamtalk.com/compare/1/6...-c1-vs-gt680w-vs-hdvr-150-vs-3h2fd-vs-mobius/
Is one or a combination of these usually the determining factor in determining from specifications alone what should have the best quality video?
Max Bitrate (Mbps)
Max Resolution
Video Format
Compression
Diagonal Viewing Angle
I thought that Mbps would be the determining factor for video quality. It does not seem to be which confuses me.
The HDVR150 shows 26MBPS but has Disappointing video quality and Large MJPEG makes huge files. 26MBPS on this dash cam is much higher than any of the others. Why is its video much worse than the rest?
It would seem to me that the higher the mbps the better the video should be. It should also capture license plates better. What am I missing? Are some dash cams using junk lenses against a fantastic cmos or is something fishy going on?
Max Bitrate (Mbps)
Max Resolution
Video Format
Compression
