The air bubbles generally go once out in the Sun for a while
Do you have any good way ? Because everytime i install, i always make some air between these.
i mean small. My mistake: it's area (acreage), not square.Just start from one side and press instead of putting all squarely.
What do you mean by square is low?
Small or thin? Small would definitely be less strong.
I don't believe that this will work, I once put a cotton thread across the middle of the pad so that air could escape through the thread, but it didn't help.I've been thinking about using a very sharp (modelling) knife to make a few slits across the 3M pad to see if it helps air bubbles escape. What gave me the idea is that mounts with smaller 3M pads tend to have less chance of large bubbles, so by making some slits in a larger pad it would be like several smaller pads.
