It does record for a minute or so, when it gets power. REC button still lighted, but LCD shows no video. May I ask a detailed set up parameters to A119 V3 , so You may assist me with the problem. I am new to Dashcam.
Maybe the screensaver kicked in? Check what screensaver is set to.It does record for a minute or so, when it gets power. REC button still lighted, but LCD shows no video. May I ask a detailed set up parameters to A119 V3 , so You may assist me with the problem. I am new to Dashcam.
Are you saying with the above settings the camera stops recording after one minute or just that the screen shut off after one minutes? Have you checked the files on the memory card?Screen Saver has been turned OFF. Loop Rec - 2 minutes , EV -00, WDR - ON, Time lapse - OFF, Motion Detection - OFF GPS - ON, G señor - Low, Record Auto - ON , Is there any other setting or configuration to be programmed for A119V3 to record continuously . Please help.
You need to try another brand memory card.BC Rural: Thanks for your detailed Infrange Dot does blink for a minute or so. , then a blank LCD Screen. I did not know that A119 -V3 still in a record mode , it shall record after the loop REC setting ( 2 Minutes ). Should I reformat the card ,re- install menu setting. Do a run with the car and see. I read that " Always reset menu to default setting, after all firmware updates " I upgraded to Firmware 1.02 from 1.00. Do I have to change or configure any setting ?
Krishan
