- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
Select the start point
Play the desired file and find the section of video you want, pause at the desired section then select View/Timeline/Set selection start (A) in current position this will flag the start point for your selection at the current playback point and the timeline will be highlighted in blue.
Select the finish point
Forward through to the desired end point and then select View/Timeline/Set selection end (B) in current position the selected segment will now be highlighted in blue on the timeline, you may also loop just the selected A-B segment to confirm your selection.
Save selected fragment
Choose File/Save selected fragment this will open the cut options where you can select how you would like to export the video segment, remove the audio track, remove the video and only export the audio track etc, click Start to export the desired segment
