camera800
- Jun 22, 2014
- Spain
Hi, I know that there are all the firmwares in this forum, just out of curiosity I'd like to know how to extract the firmware from my dashcam. Is the same way in dashcam Ambarella GS1000?. Thanks.
This is copy paste from http://dashcamtalk.com/gs1000/#Firmware_Backup
Firmware Backup
Before updating your firmware, it is highly recommended to backup your existing firmware. This can be easily done using the following method.
Firmware Backup
- Download the Backup autoexec.ash file. This is a simple text file with the following contents (firmfl gen 5 bst bld pri rom dsp d:\backup.bin). This file has the necessary commands to extract the existing firmware from the dash cam.
- Make sure the camera battery is fully charged
- Format the micro SD-card (via the dash cam or your computer).
- Copy the autoexec.ash file to your formatted micro SD-card. DO NOT copy the autoexec.ash file to the DVR’s internal memory, only to the micro SD-CARD!
- Insert the micro SD-card with the autoexec.ash file in the dashcam and turn it on. The process to backup the firmware takes about 10 seconds. However, we recommend that you wait 1 to 2 MINUTES.
- The Dash Cam will turn itself off. Remove the memory card.
- Insert the micro SD-card into the computer.
- Copy the firmware stored as BACKUP.BIN
- Rename the resulting BACKUP.BIN in accordance with the number of your firmware. For example, v4.35.210512A.bin
