How to increase frames per second of webcam capture from 30 to 60?
Mark2017
Hi Is there any way to increase the frame rate for the webcam feed to the PC?
I have a Mobius 1 that is capable of 60 fps when recording to the locally inserted SD card (tested, works).
When configured as a webcam it appears that the fps of the video sent to the PC is 30fps (used VLC media player to check the codec information, and each frame is timed at ~0.03s, ie 30 frames are captured in a 1s video).
I've changed both mode 1 and mode 2 to 60 fps using the Mobius configuration software (version 4.0.11.0, latest as at 20/10/2017) but the web cam still appears to be sending at 30fps, is there any other configuration setting that might be possible to change the webcam rate (maybe a hidden configuration setting?).
Thank you
Mark
The video modes 1 & 2 are not related to the webcam output, so changing those settings will not make any difference to the webcam video. The only options for adjusting the webcam output are shown in the mSetup screen below.
