First of all, Thank you for the understanding on mini port.Not wishing to start another debate / argument about usb sockets, but will the C3 have a standard 5 pin or the 8 pin?
If I mount the camera body under the seat on my bike and wire it as a dashcam (on & off with ign) I won't want a long power cable which I would need to tuck out of the way somewhere. 50cm would be more than enough in my case. While on the subject, I don't have a cigarette lighter socket on my bike so a different kind of power adapter, which I could wire in would be better.
Frank
you can do that quite easily with the recent versions of Registrator Viewer, there's a dedicated setting to trim the overlapDoes the latest firmware allow seamless joining of video clips?
Where is that please? I have version 5.8.0.2you can do that quite easily with the recent versions of Registrator Viewer, there's a dedicated setting to trim the overlap
Ctrl + J opens the setting for this, it's listed under View/Timeline in the menus (regsitrator viewer version 5.9)Where is that please?
Thanks for that! I've downloaded version 5.9 and found it.Ctrl + J opens the setting for this, it's listed under View/Timeline in the menus (regsitrator viewer version 5.9)
Yes, there is a marking on the lens ( camera ) housing for vertical 12-clock.Is there some marking on the lens housing to make sure it's the right way up? be disappointing to come back from a long ride to find that your footage is all at 45 degreesor upside down even
Frank
Yes! KamKar and RockThinking pointed it out earlier.Yes, there is a marking on the lens ( camera ) housing for vertical 12-clock.
You are welcome !Thanks for posting this Niko!
Frank
H | Innovv C3 issue/warning | C3 | 0 | |
Innovv C3 not found by computer | C3 | 9 | |
Innovv C3 - how to fix separated bottoms and broken plastic? | C3 | 4 | |
Innovv C3 Action Snake/Bullet Dashcam Review and Test (Gearbest.com) | C3 | 27 | |
Almost gone in 6s recorded by INNOVV C3 | C3 | 33 |
