Gibson99
- Jun 20, 2014
- Houston, we've had a problem, Texas
- Yes
I couldn't agree more. That said, of the cameras I've seen and used (which is an admittedly small pool) the CF-100 is one of the least obtrusive. It doesn't have flashing lights (you can disable the parking mode LED in software), and the status LEDs are simply on solid. there's no screen, and the brief voice prompts just help remind you that things are working properly (or not, in case of an SD card error, for example). I too want tiny cameras with a remote DVR box i can hide in the dash or center console or something, but nobody makes a good one yet. they exist, but they're low resolution and the mounts for the cameras are giant suction cups. jokiin, a manufacturer who frequents here, says they're working on a 2ch 1080p like that - tiny cameras, remote dvr - and may have something this summer or fall, depending on how prototyping and testing goes. ideally, it'll simply take +12v direct from the car (hardwire) and have battery discharge prevention built in, so you just hook it up to something like the car stereo power leads (+12v constant, +12v key-switched, ground) and don't need to mess with a lighter socket that may or may not be key-switched in some vehicles, and thus has parking mode already built in.
as for the trim in your auris - i used to be a mechanic at a toyota dealer so i got to work on everything. however, that model isn't sold in the US, so i'm not familiar with it. That said, almost all toyota trim simply snaps on around windows and doors. some use metal tabs that go under the door weather stripping, but that becomes obvious as the weatherstrip will come up with the trim when you try to remove it. on the sienna, the plastic trim around the back hatch window does indeed simply snap off. the tricky part is when the plastic clips stay on the metal body/door rather than coming out with the trim. then you have to use an upholstery tool like this to pull them out of the body without breaking them, then slide them back into the slot on the trim.
