Installing dash cam in rear, how to hide the cables saloon car with no folding seats (BMW 520)
Stushons
I want to install a rear cam but cannot see any way of getting cables from rear window into the boot/trunk.
Auld Reekie
Feed the cable under the roof lining, press the rubber seals back with your thumb and push cable under the roof lining using something like a spatula or blunt instrument, you should be able to do this all the way down one side of the car, I chose passenger side. tuck any excess cable away under the lining, remember to leave enough out at the plug ends to reach the cam's
S
Stushons
I take it u used the front fuse panel?
NextBase Support
Caerphilly
Nextbase
Are the edges of your trim solid?
If they are you could use 3M hooks to neatly put it around the ages.
