I purchased a SGGCX2 2018 (v4) from Amazon, which arrived today.
The box was correctly marked and the contents were as shown in the advert, with no cable trunking to mount above the camera.
Everything was checked and it appeared that all was in order, until i turned it on to set it up.
When i came to the version setting it showed as 01-2017. A;so in the date setting it showed as early 2017.
Also, going through the menu it had a setting for contrast. As i understand it the contrast setting has been dispensed with as being not required.
One other thing the windscreen mount was the thick version, to allow mounting on vertical windscreens. Was this supplied with the v3.
All the above makes me think this is a v3 camera in a v4 setup.
What are your thoughts?
