Thought UK called them lorries.
Lorries are usually the ones below 3.5 tons, everything else are trucks. Right, @Paul Iddon?Thought UK called them lorries.
No, a Lorry is one with a flat bed that runs over the top of the wheels for things to be placed on top of. You can have articulated 30 tonne lorries.Lorries are usually the ones below 3.5 tons, everything else are trucks. Right, @Paul Iddon?
Depends if it is a standard international scientific metric tonne or an old fashioned imperial ton of a size that depends on where you happen to be!By the way, which of these two is the correct word in British English: tons or tonnes?
The official government guide has lorries up to 44 tonnes (metric), including articulated ones, complete with diagrams:Well, I wasn't too far off but I don't think it's all about the cargo part being separated physically from the cab or covered. I've always heard you Brits call "lorry" to covered vehicles that are usually under 3.5 tons, I've never heard anyone call a lorry to larger vehicles with the same characteristics.
CThose Canadians are all over Cali and Arizona right now too. No worse than the the indigenous population.
CaThose Canadians are all over Cali and Arizona right now too. No worse than the the indigenous population.
Thanks Paul I missed that in the Forum list. I will try to get up with mod.See if you can PM a mod to move your post to the "Recorded by You" section of the forum BB.
In the UK, we don't call a truck a truck unless it has about 16 wheels, lol... I was looking for a big wagon!
So in my case it's tonnes but what about you? Do you use metric or imperial for weight measurements?Depends if it is a standard international scientific metric tonne or an old fashioned imperial ton of a size that depends on where you happen to be!
Normally we use metric tonnes. If it is an ancient steam engine then it is probably in UK imperial tons, which at 1,016 kg are not much different to a metric tonne anyway. A USA ton is only 907 kg.So in my case it's tonnes but what about you? Do you use metric or imperial for weight measurements?
Isn't that illegal?I sell chain blocks in my store, which are 1/2 ton, 1 ton, etc, but hoists are 250Kg, 500Kg, etc.
We have pipes measured by the metre and 4,8 and 12 inch engineers squares for sale.
So I would say, we use whichever we want, lol....
A 1 tonne crane is OK, that is a metric tonne.I just looked - they don't say ton, they also say 500Kg. My bad.
But there are cranes listed as 1 tonne and Halfords have 2 tonne cranes - so it must be allowed or those products would have to change. The squares say 6" and 300mm (so no probs either).
