Lola
- Jul 16, 2016
- Maryland
- Mobius, A119
I have read here that distance from glass is either set up as close or far away. I want to set my distance in the close range but how close is close relative to the lens?
What is considered the ideal lens distance for a Mobius camera used as a rear cam on a window that is vertical, lens is the "A" narrow if that makes any difference.
I don't know at this point that I will stay with the narrow A lens so I wouldn't want to handicap myself by not being able to move to wider angle lens if I wanted to for some reason, like maybe the wider angle lens is further out from the Mobius then the narrow lens.
I now have a question relative to the above question.
When you place the Mobius lens close to the widow glass I have a heavy 1 inch piece of tint that go's across the very top of my rear window.
How far should the lens be vertically from the edge of this heavy tint to not give a problem with what the lens sees through the window.
I don't have a Android tablet yet to set up/align the camera or this would be a mute point. I'm using a level, ruler, and an eyeball to get it as close as I can with out disastrous results therefore the questions .
