Those 2 you can allso disable without problems, the camera is set to allways + event, and since you have disabled the G-sensor it will not trigger a recording.
And if you disable auto-switch to parking mode, it will not make any motion detect event recordings either. ( the lukas cams allso support motion detect via the CMOS sensor )
Thats smart to use if you park in a garage or roofed parking area, as it will record as soon as there is motion in front of camera. ( providing the camera is permanent wiered to power )
Here is a good example of a event recording on a permanent wiered dashcam.
http://dashcamtalk.com/forum/thread...oiler-fogs-caught-on-dashcam.4709/#post-60194
BUT its more or less useless if you park on the streets as rain Falling on the window will trigger motion recordings, and rain / snow /dew will cover the window so in any case there is nothing but a blur to record on those days.
A camera like a dashcam use about 5 watts, so it will not drain a car battery over night, if you drive a couple of houres every day there will be no problem keeping the car battery at 100% charge ( just in case you would like to play with permant recording 24/7/365 later on )
I have allso disabled the security LED as it just attract attention, and i do not need to make some guy with a short fuse mad. ( especially in NYC
I would keep the high temperature safty on, as i recall NYC can heat up quite good in the summer.
