Al Drake said:
BugCam said:
Anybody tried to connect the LK-7900 ACE AV output to a Magellan RoadMate 1700? According to the Magellan website the RoadMate 1700 requires a 3.5 mm. but it needs three rings according to their website, it also says that a two ring connector will fit but not display video. Are there 3.5 mm. two to three ring cables that will work or do I have to custom wire it and how do I do that?
Thanks in advance for any reply!
Arthur.
I have the RoadMate 1700 and RoadMate 9250T-LMB and have them both working fine with any standard video out signal. You need to switch the yellow and the red on the signal into the RoadMate. Yellow and black are audio and red is video in.
That would mean that Magellan uses a different standard then most other manufacturers and after some more diggin' you're right, instead of using the tip of the three ring connector for the video signal they are using the ring which is normally used for the audio signal so with a standard two ring connector you would ground out the video signal. So now I have two options, making my own custom cable or re-wiring the RoadMate, how difficult was the re-wire?
