- Apr 27, 2015
- Unit 170-2188 No.5 Road Richmond BC
- Canada
- Lukas, QVIA
Installation
on Civic 2015
![11281799_10153430076592728_1188926832_n_zpsb781ycej.jpg](/forum/proxy.php?image=http%3A%2F%2Fi296.photobucket.com%2Falbums%2Fmm188%2FWitness_Auto_Dash_Cam_and_Accessory%2F11281799_10153430076592728_1188926832_n_zpsb781ycej.jpg&hash=5d2cf0888cac960443c6662a988b3d48)
![11429632_10153430076512728_1817091213_n_zpsgbrexa8d.jpg](/forum/proxy.php?image=http%3A%2F%2Fi296.photobucket.com%2Falbums%2Fmm188%2FWitness_Auto_Dash_Cam_and_Accessory%2F11429632_10153430076512728_1817091213_n_zpsgbrexa8d.jpg&hash=3394882a2c26a4ef34e583a6d9b70678)
![11420057_10153430076437728_506372958_n_zpsce7qj8ch.jpg](/forum/proxy.php?image=http%3A%2F%2Fi296.photobucket.com%2Falbums%2Fmm188%2FWitness_Auto_Dash_Cam_and_Accessory%2F11420057_10153430076437728_506372958_n_zpsce7qj8ch.jpg&hash=8381801b81d2e28108f2e3b371ee3684)
On BMW 435i
![11813247_920461108027709_1039917339969253645_n_zpsuqfroi7h.jpg](/forum/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fs296.photobucket.com%2Fuser%2FWitness_Auto_Dash_Cam_and_Accessory%2Fmedia%2F11813247_920461108027709_1039917339969253645_n_zpsuqfroi7h.jpg.html%5D%5BIMG%5Dhttp%3A%2F%2Fi296.photobucket.com%2Falbums%2Fmm188%2FWitness_Auto_Dash_Cam_and_Accessory%2F11813247_920461108027709_1039917339969253645_n_zpsuqfroi7h.jpg&hash=9de50bf1b629d8afd8fabef16e78b231)
![11813247_920461108027709_1039917339969253645_n_zpsuqfroi7h.jpg](/forum/proxy.php?image=http%3A%2F%2Fi296.photobucket.com%2Falbums%2Fmm188%2FWitness_Auto_Dash_Cam_and_Accessory%2F11813247_920461108027709_1039917339969253645_n_zpsuqfroi7h.jpg&hash=af39b33e7da2503929943aa33964ad80)
![11707604_920461144694372_2313580101174175171_n_zps7uip9mr4.jpg](/forum/proxy.php?image=http%3A%2F%2Fi296.photobucket.com%2Falbums%2Fmm188%2FWitness_Auto_Dash_Cam_and_Accessory%2F11707604_920461144694372_2313580101174175171_n_zps7uip9mr4.jpg&hash=620d621a54279d75d873222abe659335)
![11781685_920461094694377_4403611128598375815_n_zpsgfverdth.jpg](/forum/proxy.php?image=http%3A%2F%2Fi296.photobucket.com%2Falbums%2Fmm188%2FWitness_Auto_Dash_Cam_and_Accessory%2F11781685_920461094694377_4403611128598375815_n_zpsgfverdth.jpg&hash=36ca2f6d79d41c6515a21d2b8a9d6b0f)
![11800467_920461151361038_4585881703390943304_n_zpsqe0wmdwy.jpg](/forum/proxy.php?image=http%3A%2F%2Fi296.photobucket.com%2Falbums%2Fmm188%2FWitness_Auto_Dash_Cam_and_Accessory%2F11800467_920461151361038_4585881703390943304_n_zpsqe0wmdwy.jpg&hash=3ce7ce2c35ced388ffe880d10e396800)
LK-9350 DUO is one of the latest and best model of LUKAS dash cams. It is an upgraded version of 9300 that comes with interchangeable UV lens; plus the stylish design and coloring in piano black. The main camera will be mounted at the front windshield; the rear camera will be attached on the rear windshield and records what’s behind you. It also comes with a 3.5 inch LCD screen where you can see the real time recording from the rear camera.
Front cam is built as 2.4 Mega Pixel CMOS Sony IMAX 322 full HD image sensor with 1920x1080p resolutions; the rear cam is built as a 2.4 Mega Pixel CMOS Sony IMAX 322 Full HD image sensor with 1920x1080p resolution. The front camera operates 30 fps (frame per second), on the other hand, 24 fps (frame per second) video recording.
LK-9350 DUO has dual memory card slots. One is for SD card, which is normal recording; and the other one is for micro SD card, which is for event. It comes with one 8GB SD card and one 8GB micro SD card and can be upgraded to 256GB each, which is the highest capacity in the market. It has wide viewing angle with front 135°/ rear 130°; and operating temperature is from -20℃ to 70℃. The size of LK-9350 DUO is front 111x99x37mm with 161g at weight; and rear is 50x26x31mm with 25g at weight.
Lukas equips a parking mode system within LK-9350 DUO, which means the camera will record after you park and leave the car. It comes with a motion sensor; if it detects any movement, it will automatically turn on and record with the 10 seconds before and 20 seconds after the motion is detected. The device has low voltage cut off function, which will not draw any power from the car once it detects the car battery is at low voltage level.
Multiple-language menu supports English, Spanish, Russian, Chinese (Simplified), Chinese (Traditional), Japanese, French, Arabic, Thai, Vietnamese, German, Italian, Mongolian, Turkish, Hindi, Czech, Portuguese, Bahasa Indonesian, Malay and Korean.
Optional Accessories:
- Lukas CPL Lens Filter
- SanDisk Ultra micro SDHC Memory Card with Adapter
- 2-Channel 2.4M Pixel Sony IMX 322 Full HD CMOS image sensor
- Front cam: IMAX 322 Full HD CMOS image sensor/ 1920x1080p,30fps
- Rear cam: IMAX 322 Full HD CMOS image sensor/ 1920x1080p,24fps
- Wide Viewing Angle
- Diagonal angle: Front about 135 °/Rear about 130°
- 3.5 Inch LCD Full Touch Screen
- Resolution: 800x480p
- PIP(Picture in Picture Front/Rear View)
- Durable Saving Function of Event Moment
- Dual Save: Always + Event
- Dual Slot: SD + microSD
- Multiple-language Support
- English, Russian, French, Korean, Japanese, Chinese, Spanish and Arabic
- Up to 512 GB: The Highest Memory Capacity in Market Today
- Equipped with Car Battery Discharge Prevention Function
- ACC and multi-booting option support (Leakage current: less than 100uA)
- Security LED lamp on both front and rear cams
- Storage of 1M Driving Information Data
- High temperature safety sensor
- 37mm UV Filter / CPL Filter(Opt.)
- Dual-Core GPS + GLONASS(Optional)
- Parking Surveillance Notice
- Lukas Dedicated Viewer for Mac and Windows/Firmware Updates
- Easy installation of Rear Cam
- Can be mounted on the rear windshield regardless of sun shades
