kamkar
- Oct 11, 2013
- Denmark
- +1 decade, many dashcams
I am looking for a camera you can connect directly to with a phone with a APP or ip adress in a browser, i think it need to have a external antenna / a antenna you can put on a wire.
CUZ the camera are going to be in a stable, which are some distance from the main house where the footage need to be viewable, so i was thinking if you put the antenna on the outside of the building there might be a chance.
Even if it is not far i dont think a wired camera would be of any use, well at least not without some box in feed into, and to what you can then connect with a phone, so pretty much a IP camera or other form of wired cam.
But i am trying to do this cheap and without too much fuss as the people using it, are not super tech minded, but a APP on a phone or maybe a IP address in a browser i think they can handle once set up.
I haver not yet looked to see if the houses WIFI router can be seen in the stable, but i somehow doubt it as there more or less is a building in the way
