Now on LTO:
As good as LFP batteries are, from the safety stand point and for the Dash Cam application, LFP Batteries have a one major shortcoming - significant loss of usable capacity and most importantly
the inability to charge at sub-freezing temperatures.
Even so, I live in a warm climate, we still get several days of sub-zero temperature here, and the freezing conditions contribute to a bad road conditions and accidents, this is when the Dash Cam is needed the most.
You can imagine how important this is for drivers living in a cold climates with long periods of frost.
The main reason for this project is the superior low temp performance of LTO chemistry Battery, capable of charging/discharging at deep sub-freezing conditions, while having similar to LFP hot temp performance.
Not less important is that LTO batteries have a superior life longevity and are the safest batteries out there (even better than LFP).
The goal was to build simple and affordable LTO Battery Pack, capable and feature reach and with all the required protections, using off-the-shelf inexpensive components, so anyone with basic DIY skills could build it.
For starters, here are couple of videos. One for Viofo A229 Plus 2ch parking duration test and the second one showing charging after the test.
Also a couple of pics showing early stage charging tests, note, that there is no BMS yet.
I will post more videos and pics as we go.
EDIT: I later upgraded this 7S battery to 6S with more features, see post #368 and subsequent posts.
EDIT: Also see post #25 for 4S battery later upgraded to 5S
