Maximum / minimum angle on WR1 mount?
joe384
Essex
2 x DR590W-2CH, Cellink B
Hi,
Does anyone know if the 3m sticky mount is able to mount at right angles - eg. on side window?
SawMaster
SC
Numerous and ever-changing
As long as it's attached to the cam mount correctly, and as long as the surface it's mounting to is smooth and clean, it will stick about anywhere. Do be sure that the cam can be aimed where you want before sticking it since it's near impossible to unstick even a portion of the tape once it's made contact. For best results leave the mount attached without the cam installed for 24 hours after attaching so the tape bond will adhere better. The mount for this cam is not as robust as some others but it's plenty good enough as long as it's not abused.
