well, I'd be a little affraid to use a 6 cent charger with my dash cam what voltage does the Mobius require?
That's right - just get a decent USB car charger than can supply 1A or greater and you should be good - if you already have a phone charger then check the specs and if it outputs 1A or above you're good.
I personally use two of these:
https://www.amazon.co.uk/gp/B00E1UWA4O
To be honest if you went straight for the Mobius then consider yourself lucky - there are much worse options on the market!
I did extensive testing with v2.10 and v2.12 (test version) using Sandisk, Kingston, PQI and PNY 64 GB cards formatted with FAT32. There was a BIG difference in the results. I basically had zero problems using v2.12 whereas v2.10 gave erratic and unreliable results. After v2.12 came a lot of intermediate FW versions so I didn't have a chance of continuing my tests. Today I started testing the same cards with v2.18 but this time formatted with exFAT. The problem is not so much the firmware, but more the codes from the chip manufacturer which are linked into the firmware. The developer almost always uses the very latest codes provided by NTK but, unfortunately, there is no guarantee they will work the same as in a previous version. The only way to be sure is test, test and test again.I started reading this thread cause my SANDISK ULTRA 32GB won't record from 1.17 and up.The leds are flashing like it's recording, but NOTHING is actually written to the card. The maps DCIM and supmaps are created but that's it. I've tried formatting in PC and Mobius, no go. The card seems OK because I can copy paste delete any type of file, but Mobius is not writing the clips in the folder.
Which is weird because I have a same type/brand 64GB that DID work, but locked up for some reason, it's on an RMA status with SANDISK, I should receive a new one soon.
At present I use a noname 32GB that works fine, in ALL version F/W.......!
Now I really need 64 GB because of the longer recordings/trips, and I would like to know who has good experiences with their 64GB card in Mobius?
Please let us know which ones.
I don't know what you mean by "locked up", but if you mean your card flipped to read-only then that is a (common) problem with Sandisk.
From all the problems posted, Sandisk cards seem to be far the most vulnerable. Although I haven't had any compatibility problems myself (except for two flipped read-only cards), I can only advise to avoid Sandisk cards. Kingston have the best reputation.
If the card routines in the NTK codes used in v2.18 are identical with those used in v2.12 then I expect far less card compatibility problems. Let's hope NTK hasn't changed them.
Until my testing is completed, I can't make any other comments on card compatibility with v2.18, there are just too many variables.
there are also many Sandisk fakes on the market. I bought a Transcend 32GB Class 10 card, hope that everything will be ok with it.
I'm intrigued by these Sandisk cards flipping to read only - are they dead in things like Linux too when they go?
do you guys think that the 3 meter cable would be enough to properly install Mobius in a small car?
