Mini 0803 Firmware Request Thread
David Pincus
+ Add option to disable sounds (beeps)
+ Add option to disable blinking lights (on, off, off when screen is off)
+ Add option to watermark speed onto video (when available) in M/H or Km/H
+ Add a 'space' or blank character to the text watermark field
Good to have 0803 "wish-list" thread.
P.S. - change a title from 803 to 0803 ;)
+ Add option to mount up side down (invert image, 180° rotation)
+ Add option to increase volume of audio beeps
+ Allow selection of MPH / KPH in GPS menu.
+ make the 0803 compatible with 64GB exFAT format memory cards.
If you don't ask you don't get! ;)
If it's isn't possible, nothing lost nothing gained.
it's possible, the chipset supports it, there are license fees involved as it's a patented technology, given the price point I'd suspect the factory probably wouldn't be keen on spending the money required though (it's quite expensive)
I'm sure if the Russian's ever decided to work on this model it would happen ;)
If it isn't possible, nothing lost nothing gained.
I have posted in the 0803 coming thread. 64GB cards are working formatted with fat32. It is a band aid, but it works. ExFat would be better. Camera would format 64GB with ExFat by default, but it would not use it. Where to get latest FW?
I copied the " 0803_20140424_V3_EW803.bin " file to the sd card and started the camera. But do not start the firmware upgrade, but the video starts.
I get the update failed message. On reboot the camera is in a frozen state with a constant chirping sound. Once the battery dies it starts up ok with the old firmware. Help please!
