- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
to be 'fully supported' any card would be able to be formatted in the camera
I don't possess a 128GB card but I do have two 64GB Cards, both Samsung, one Evo and one Pro, both of the latest generation. I will try to answer your questions better than has been done so far.Excellent points. These questions should be addressed in the 0806 user manual. It would be valuable to know if the 0806 formats the 128GB cards directly or if there's something funny about the way they're used. Who knows? Maybe when we try to use a 128GB card the 0806 won't format it and then you have to go and buy an SDXC reader for your computer before you can use your new 0806 with the undocumented memory cards. I have a master's degree in engineering and I still get burned when I buy "stuff" without exhaustively running down every miserable detail. Just the fact that all the answers so far are of the "bait and switch" variety is enough to make me want to dig deeper. In my experience, if you don't ask these questions, you **will** get burned which translates directly into money wasted.
Are you saying it wont work or just that it is not ideal? Not ideal is fine as long as it works, most of the time it only needs simple sequential access not high speed random access. It certainly seems to work very reliably at 64GB and as long as the address size for up to 2TB is supported I don't see why that would work any differently...The support for 2TB is intended for SSD and USB hard drive use, not suited to this design obviously and it's not built on the right SDK either
Well 2 x 512GB SD cards via adaptors to give 1TB is physically possible right now if someone has an application which justifies it...SSD or USB hard drive wouldn't work, wrong SDK, the product isn't designed for them though so no big deal
If MicroSD cards large enough were available they would most likely work when formatted FAT32, they're not so it's impossible to test but they 'should' work, they haven't claimed support for anything larger than 2 x 128GB at this stage which is the practical limit that anyone would be purchasing right now anyway
I wouldn't touch that with a barge pole - the only one I see is $65 now.Pressing a link from this thread showed me the 64GB on Amazon and pressing more I found 128GB for $55 in USA. Maybe a mistake?
Do you have to put the firmware on both SD cards or just on one for mini 0806?
T | Mini 0806s GPS modul dead | Mini 0806 | 1 | |
S | Mini 0806 Battery and Firmware | Mini 0806 | 0 | |
M | there is a listing of the error codes for mini series or for mini 0806 | Mini 0806 | 2 | |
Replacement mini 0806? | Mini 0806 | 3 | ||
mini0806 - should it work with 128GB SanDisk microSDXC UHS-1 card ? | Mini 0806 | 27 |
