- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
Processor on these only good for 45c?
I just tested it and it's the exact opposite.The white line should go exactly at the top to remove reflections from the windshield.
Looking at the videos right now, G90 is much better in comparison against 0806's videos with CPL filter.Your 0806 appears to be less sharp then mine. Perhaps bad focus on the lens out of the factory. Could you also try in the pitch black?
G90 doesn't look too bad though, I wish it had better design without using suction cup.
Look at this screenshot from one of your videos. Clearly shows that left side is out of focus where the trees are. Did you not remove protective film perhaps?
I didn't see film cover on the CPL but will double check.File path for Mini 0806: F:\DCIM\101MEDIANot sure what's wrong but looks like the focus is not sharp in the mini 0806 compared to G90 A7LA70.
It could be the CPL filter.
Yes, I removed the plastic lens cover so that's not the issue.
I'll remove the CPL filter tomorrow and see how that works out.
Also, CPL is not doing much with the white mark on the top.
The screenshots are much lower resolution.Yeah, but my non scientific opion is that G90 looks identical to my 0806 in terms of IQ, the only test I wonder is how it performs at night.
A lot of your images aren't showingBTW, are you guys seeing the screenshots within the body?
I have red x on the images. Thumbnails on the bottom are fine.
The images are in the thumbnails anyways.A lot of your images aren't showing
You will find that it works just as well with it at the topI just tested it and it's the exact opposite.
The white mark should be on the bottom. :s
The edges are probably not as clear due to motion blur, the edges appear to move fastest. Compare images while stationary to find out if this is the case.For your reference, here is a screenshot from my camera. Windshield not 100% clean but OK. setting 2560x108. The edges left and right are not as clear as on the G90 screenshot,
maybe to do with the charataristics of the windshield, ie edging off, or more straight perhaps ??
Seems your vids are much lighter. Mine are made on a very sunny day, still find them a bit dark. How should White Balance be set? Currently to AUTO.
Does the setting 'Sunny' means to use in Sunny weather, or are the videos then showing more light (sun)?
Not sure how to interpretate that. Any tips ? Or should I use Exposure Compensation for that, and if so, what setting is recommend to get a 'lighter'video ?
sorry, which camera is this from again?For your reference, here is a screenshot from my camera. Windshield not 100% clean but OK. setting 2560x108. The edges left and right are not as clear as on the G90 screenshot,
