Nigel
- Jul 7, 2014
- Wales
- United Kingdom
- Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
I think if you asked your supplier if he minded you disassembling it and having a go at refocusing it rather than send it back then you would get permission. The advantage is that you can get it perfect instead of just good enough for sale.Nigel,
Pretty adept at a bit of DIY, but what worries me is the fact that it's focussed to one side - indicating a possible angular alignment issue that would be impossible to adjust. I need 4 cameras, and potentially pulling 4 apart and failing and then having the issue of returning them where the supplier sees that I have taken them to bits - not worth bothering with.
I'm holding off until the next batch come through....
Due to the wide angle lens there is quite a large depth of field so slightly different focus left to right probably wont be an issue, I guess they all have that issue but it's not normally visible since both sides will be within the depth of field.
I've not got much idea what percentage have problems, hundreds have been sold but we have only seen a few with problems and I guess at the moment we would hear about a lot of the ones with issues?...
