Mivue 792 wifi pro + mivue A30 random length of recording
Michalll193
Gliwice
Poland
Dashcams monted with mio smartbox, memory card is SANDISK microSDXC 128GB speed class: class 10, UHS-I / U3, V30. Records has random length despite the fact that I changed in settings records length to 3 minutes. All records has length from 15 seconds to 35 seconds. What is the cause? Should I look for sth in settings or sth is broken?
Hi Michalll193,
if you disconnect the A30 (rear camera), do you still has this issue?
I just found out, when I disconnect the A30, I don't have this problem anymore. I want to inventorize if other people are having the same issue. If so, Mio has to fix it! And mabye also other brands are having this problem when using multiple camera's which are writing to the same SD-card.
If you have 2 channel system, and it is acting funny, unplugging the remote camera at the main unit and test with just 1 camera is one of the first things you should try..
Also if you are not using the provided power source, you should try that.
