StrangeOrange
- Apr 25, 2016
- Afghanistan
- Mio MiVue 388, 588
Hello,
Has anyone tried making changes to the firmware on a Mio MiVue device? Mine's a 588 but I think the procedure is similar across all the 5xx as well as possibly 6xx device range.
The firmware file SD_CarDV.bin is neither compressed nor encrypted, an can be sifted through with utilities such as strings or binwalk, and potentially interesting areas can then be modified with a hex editor.
There is a certain obstacle with the checksum being verified upon attempting to flash a new firmware. One way to go around this restriction is to use a hardware programmer with a desoldered memory chip. It has been documented (originally in Russian), although the author's objective was to recover from a hardware brick, so just for experimentation's sake it might seem like an overkill.
Another solution would be to recalculate the checksum after modifying the firmware. The 16-byte hash is stored in the firmware file at bytes 16-31 (bytes 0-15 are the common header, and the actual flashable firmware file starts at offset 32).
If anyone tried experimenting with the firmware, please share your findings.
Fun fact: along with one of the previous versions of the 588 firmware, Mio accidentally posted all the tools they themselves use to generate the SD_CarDV.bin file. Unfortunately, having realized their mistake, they eventually updated the download to remove them. The file name was MiVue588_SD_CarDV_VS00.0C.06.FT1.zip , and the download had the size of 10.7 MB, while the updated file without the tools, available from Mio's website as of now, is just 5.2 MB.
