TonyM
- Jul 30, 2013
- United Kingdom
- Many dashcams over many years
If it's not the battery then it could be a FW or setup issue. I mentioned the battery first as that's usually the primary reason for clock errors.On both occasions this has happened to me I have put the Maxi on charge but the Green light goes off after a couple of minutes. I have then fired it up and the Maxi records for around 90 minutes. I doubt this is a battery issue.
How do you setup your camera? With mSetup, mobile app, or manually editing the syscfg file?
