Modified firmware for Thieye T5e and clone...
x4080
Indonesia
Thieye T5 (180119) MOD#1
The a la Protune mode is activated for all modes.
Try, compare with the Stock FW and describe the impressions.
Based on your comparisons, I will think about further changes.
Changed the digital effects to less radical in terms of saturation and brightness.
The effects menu has not yet been renamed. No change is just the effect of the 70s...
Do you have the link for the firmware mod ? Thanks
d00m303
Poland
too saturate imo.. useless to color grade and correction
Mighty777
Switzerland
Mini 806, ThiEye TM5E, Xiaomi Yi, Xiaomi Yi 2 4K
awesome! just two questions about the autoexec.ash below:
#Bitrate VIDEO ThiEYE T5&T5e_V5.1 (180419)
#4K Bitrate 100Mbit [0x42C8] Type - CONSTANT [1]
writew 0xA0574032 0x42C8
writeb 0xA057402C 0x01
#3.7K 80Mbit Bitrate Type - CONSTANT [1]
writew 0xA05745A2 0x42A0
writeb 0xA057459C 0x01
#1080p 60fps 600Mbit Bitrate Type - CONSTANT [1]
writew 0xA05742D2 0x4270
writeb 0xA05742CC 0x01
1) for 1080p I assume 0x4270 means 60Mbit bitrate, and not 600, right?
2) what is the 3.7K resolution? Is the 2560x1440? If so, this is the one you pumped to 60fps?
Mighty777
Switzerland
A banal error in writing...)
This is exactly 2560x1440p 60 frames per second. The name is conditional by the number of pixels.
Thanks...I assume then there is a typo and it is 2.7K and not 3.7k :)
In any case ;-)....it seems I have a problem...when I set 2560x1440 60fps (by selecting 1280x720 60fps in the menù), the video file I record is at 1280x720 and not at 3.7K.
I do not know if the fact that I use it in PAL (25fps) rather than in NTSC (60fps) makes a difference...I believe it should not, but this is what I got thus far... :-(
d00m303
Poland
aa okay ;) so can u Guys share these settings or autoexec? constant 100 is not good for many users as they have cheaper cards.
d00m303
Poland
Nice ;) just a question - can u do 100/80/60 super fine fine normal settings for all resolutions?
I tested it with my quadcopter and looks good, nothing hangs
any way to enable fpv out when screen is off? Cause now i need to fly with screen on to have fpv signal,
U guys making great work for this cam, much better than thieye themselfs
Greets!
kawa
Italy
It is difficult to recover the file on the Russian site :(
kawa
Italy
I have the Andoer AN7000 which mod would be good for my not having the external mic?
On the forum I found the MOD.1.1 180419 MIC 16.05.2018 but not the MOD 1.2.
Can I use a MOD 1.1 for the test?
kawa
Italy
ok I found MOD 1.2. Is it ok per AN7000?
d00m303
Poland
i found bug in 1.1 - 2,7k aktually records in 720p, it just show in osd 3.7k
d00m303
Poland
i was filming with my quad today - i used to set 720p @ 60 which by the firmware should be 1440@60, it was showing in osd 3,7k but all my vids was recorded in 720p....
Just flashed 1.2 and it works like it should - setings 720p @ 60 actually records 1440
Aussie Kev
Sydney
Ion Adventure
2560 x 1440p60 would be great! :D
bajsryssen
Sweden
Can someone post the download for mod 1.2 t5e? It's for me, impossible, to register on that russian site. No email is sent upon trying to register.
And all I can find with google is the russians linking to the same damn forum. :)
Aussie Kev
Sydney
Ion Adventure
Same. They registered me OK but the site has a CAPTCHA that is impossible for me to verify! I have an English keyboard! :oops:
Aussie Kev
Sydney
Ion Adventure
You can use a virtual keyboard or use Character Map.
It would be a desire...)
It's really hard to make out ... like "hand written" characters on 4PDA sadly.
They have option to email you a 4 digit number but it never works. Says it will take 1 minute but never arrives?
I've tried, especially as they did originally email my acceptance to 4PDA as accepted and verified.
Will try and find a good character map and try again though :)
bajsryssen
Sweden
Why even refer all talks about this firmware to another forum?
Post it here or dont post it all, tbh.
Aussie Kev
Sydney
Ion Adventure
I think you'll find the modded f/w COMES from the same users on other forums and just lucky the authors bother to post here at all.
This is predominantly a Dash Cam forum and Action Cams are a side item that tends to use similar hardware and firmware plus related Dash Cam menu options making them useful as Dash Cams hence their inclusion on this site.
