I have the Viofo Hardware Kit!
I checked when the camera powered off, i tested red wire of hardware kit and i was on 12.1~12.2v but without any power on camera.
But if i don't touch the car all night. the camera won't power off...
It's clear for my that you have Viofo Hardwire Kit.
Now I also have Viofo Hardwire Kit. But I had Black Vue Power Magic Pro before. And I had the same problem as you.
After replacing Power Magic with Viofo Hardwire Kit my problem was solved. Viofo Hardwire Kit do not switch off camera after short voltage drop.
Did you checked the voltage after closing and reopening the car?
Or you sat in the car, closed the doors using central looking and checked the voltage before reopening?
Why it is important - in most of the Honda cars some circuits are switched off while doors are locked from outside. One of the examples is interior lighting. When you turn cabin light on (permanently, not auto/door position), cabin light will be switched off after locking the doors using central locking. And will be switched on again after unlocking.
