The nice but now obsolete dashcam player Registrator viewer automatic detected your driving sessions and sorted them as such, so using that you could export a driving session as one large video with 1 - 2 clicks of the mouse button, or just effortless play the driving session as 1 video.
BUT ! this piece of software are no longer a option as the maker of it died years ago and so it no longer support modern cameras with modern hardware in it.
I have requested that the maker of the player named Dashcam viewer incorporate the same nifty functionality in his program, but i have no idea if he will do that or have done that.
I cant recall if dashcam viewer bundle / arrange the video clips into drive sessions, so you can just use that as playback to play a entire session so you can just FF thru it or REW if you want to go back.
I do have the software ( not installed ) but i never use it as i just use a regular video player, which will also play your videos as one big video but you manual have to highlight the files in a session and then select play.
Hi everyone. We just released version 1.2 of Dashcam Viewer. This version supports the 3-axis shock sensors in the Mini 0801. Data from these sensors are displayed in the Graph window. Current DCV users can download the new version using the "Check for new version" feature under the Help menu...
dashcamtalk.com
As said above you can make the camera not loop record, but then it just record videos about 4 GB in size ( around 15 minutes of recording time as i recall ) but then the camera will just stop recording when the memory card fill up.
And that the camera will keep recording the the memory card are full are sort of a corner stone of dashcams, so you will never really run out of space just when the card are fill the oldest recordings get deleted to make room for new ones.
And if people have to keep a eye on when the camera stop recording as the memory card are full, that also violate another cornerstone of dashcams, that being that they should not need any human interaction or at least as little as possible.
