I follow the forum here and finally decided to get A119 rather Opia2, out of box the unit looks solid.
Before I connect with cg charger, I powered up with 5v powerbank. It's the old default firmware, I found Rec button wouldn't stop recording. I expect the firmware update would fix the issue.
I installed the update, set all to default, format SD card from main menu. But the firmware is still the same old, even after my three times try. Also all buttons are lagging, like Menu, Rec, etc takes like 1 - 2 sec to react. When I want to spin the car to try on the road, I realized the cg charger is faulty...
Not sure if anyone had the same issue, with any remedy to fix? Thx all...
