Allwinner solution doesn't do 1080p, will be 720p max for primary camera and VGA on the secondary, I guess being through eBay you'll at least be able to put in a claim for not as described to get your money back if you're not happy with it, return postage will take a bit out of that though if you do
Why is that?
If someone sells you something that is either faulty or not as advertised then the seller should reimburse surely?
A few years ago some sellers would advertise an item at 1p with a £49.99 postage rate & then state in their Ts & Cs that they would only reimburse the cost of the product!
I'm sure they sent out dodgy gear on purpose. Every time I found one of them on ebay I reported them, although I got the feeling that Ebay couldn't have cared less, as long as they got their cut of everything.
Take note, most claim they can do 1080p, well most of them are not lying but at what frame rate?? Almost all of them does 1080p at 10-15 frames per secs. To get a full 30 fps, you have to lower your resolution to 720p only. Only a few brand out there can do 1080p at 25-30 fps.
I wouldn't trust it, as the seller is also selling a Carcam K2000 but not specifying it's name, claiming it records in HD while being $32. Looking at the store, it seems to steel knockoff products (or dashcams).
