erewhon
- Dec 17, 2012
- Atlanta, Georgia
- BlackVue DR500GW-HD & DR650-1CH
Such an astounding job erewhon. I'm looking to purchase a complete set... I have the filter purchased, now I simply need to purchase your adapter. $20 shipping is steep but looks to be worth it. Plastic or detail resin? Before I buy the adapter, I am wondering if I should hold off because of your new design. Only question I have regarding your new design is your clip will end up covering some ventilation holes. Think that will be a problem?
Hello Agilis,
Thanks for your comments!
From Sculpteo, the expedited shipping charge for one original adapter was $6.50, from France to Atlanta GA, USA. From Shapeways, the standard shipping charge was also just $6.50, from New York. Where are you getting the $20 shipping charge?
For the new prototype design, I ordered one in detail resin and one in sintered polyamide powder from Sculpteo, and I ordered one prototype from Shapeways in sintered nylon powder.
The detail resin is a much smoother finish. The sintered products have a slightly sandpaper-like finish, which sandpapering and paint cannot eliminate. Resin looks nicer. However, the sintered products are supposed to be more flexible, and the Shapeways sintered nylon powder appears to be the most heat tolerant of the three materials.
On the original design, the press-fit might slowly deform the adapter. The adapter I have been using (made of Shapeways sintered nylon powder) still fits snugly, but nevertheless seems a bit looser than when I first put it on. In the long run, a touch of mild adhesive of some sort might be needed.
The idea behind the clip adapter is that once installed, there are no further stresses to deform the material. Also, there should be no need for sanding and custom fitting. With the three different prototype materials, I'm trying to get a subjective feel for the "best" material, and possible refinements to the shape.
You are right about the clip and the ventilation holes. Six holes are covered. There is a security LED just below the lens on the dashcam. The original adapter did not cover the LED, but the view was nevertheless blocked from the front of the car. You have to put your head on the dashboard of your car and look straight up to see the LED. I therefore used dashcam settings to turn the LED permanently off. This might also reduce heat a bit. If you look closely, the two ventilation holes closest to the LED are already blocked and are non-functional. On the bottom of the mounted dashcam, only the two holes in the next row are actually blocked by the clip. On the top of the mounted dashcam four functioning holes are blocked. Photos in the dashcam comparisons show that in the BlackVue, most of the electronics are located away from the blocked holes. Close to the top four blocked holes is the capacitor that holds enough charge to power the BlackVue during shutdown. I assume that the capacitor does not generate much heat during operation.
Nevertheless, I'm looking ways to uncover the ventilation holes in later designs. There will be more prototypes!
![Stick out tongue :p :p](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
