LateralNW
- Nov 7, 2016
- Australia
- VArious
Swap the MicroSD card to another Vantrue one if available and then repeat testing. See if you encounter any issues. This would be the first step to troubleshoot. If the issue goes away, you've narrowed it down to the SD Card. If the issue persists, then it is either a faulty 12V adapter or the camera may be faulty.
Note: Should you not have a spare Vantrue MicroSD, run Sd Card Formatter and do an overwrite format on existing card.
Please follow these steps and report back your results.
Thanks for your suggestions but I think you have missed the most important part, and that is the files are damaged and need to be repaired otherwise the hours of the trip are lost.
Regarding your suggestions do you realise that the memory card recorded the internal videos without a hitch as I mentioned above? It would be weird that the card is selective in the files it is saving correctly.
I think the sensor or the bits that manage it went a little haywire.
As a user I they would prefer that the files are fixed than to play around with SD-cards, power etc.
If you have a suggestion on how to repair the files I'm all ears. I do have a few ideas up my sleeve that I am going to try.
This was a one off trip and I expected the Vantrue N2X just to do it in its sleep so to speak.
My intention was to make a video about the trip on my YouTube channel with glowing praise. I won't be doing that now.
Regardless of the brand, reliability while recording is expected to be the highest priority.
