The Vantrue design team decided to announce the important design details of Vantrue Nexus 5 in advance.
Vantrue hopes that customers, technology enthusiasts, and competitors can make some suggestions and discuss how to make better products for the automotive safety industry.
View attachment 64868View attachment 64869View attachment 64871View attachment 64872View attachment 64873View attachment 64874View attachment 64875View attachment 64876
You would think so with the N4 Pro as same guts, but obviously since N4 Pro is running 4k with IMX678 it's all constrained by the processor demands. Hence that's a 3 channel and the N5 is four channel.Nice to see the insides of the Nexus 5 saves me pulling apart the one you supplied me.
A couple of take aways for me are,
7.5Farad @ 5.5 Volts Capacitors
That is a huge capacity and answer a question I had about how the Nexus 5 remains powered for so long after the power is removed.
The main board of the N5 is the N4 so does that mean the N4 can run 4 cameras?
Kinda is but I guess they can do more. Will see what the future holdsAny chance we can improve the heat dissipation, such as using thermal paste, copper heatsink, etc??
Copper vs aluminum in this case, pun intended, will have minimal impact and they are already using a silicone grease based TIM. If the case is anything like the N4 Pro's, only active airflow will improve things. Unless you get a billet aluminum case made to act as the heat spreader.Any chance we can improve the heat dissipation, such as using thermal paste, copper heatsink, etc??
Not sure they can because of the capacitor but I would imagine there's some kind of intermediary solution for thisCould they add "battery backup" of settings - so you don't have to re-configure the DashCam EVERY time after a Software Update???
9 | Nexus 5 Unboxing | N5 | 54 | |
Nexus 5 by Vantrue N5 In-depth look | N5 | 9 | ||
Vantrue Nexus 5 4CH 2K / My introduction to the new model. | N5 | 32 | ||
Vantrue Nexus 5 improvement wish list | N5 | 5 | ||
Vantrue Nexus 5 samples/impressions | N5 | 13 |
