gse
- Oct 22, 2013
- Russian Federation
- Viofo 119V3
On the bitstream, the bitrate is variable and the recorder starts at 7,800, it rises only in complex scenes where there is no hardware limitation, and we make it permanent and start starts at 14,000, if you put 15,000, then there is already a limit.But i don't understand why. In the past [i used 28000kbps] I've had some recordings with a video bitrate up to approx. 43000kBit/s (most at 30000-34000kBit/s).
So the limit should not be by the Hardware.
The bitrate above 14000 = 28000, it will not rise above, it will be a constant 28000Otherwise, I will do without the parking mode and set the bitrate up to 28000 kBit/s and get Videos with 28000-43000kBit/s
