You're welcome. Find your vehicle's manual and I'll take a peak on what fuses are most ideal. I'm not sure what fuses a Sante Fe uses (Micro, Mini, etc). Per my image: I assume this link is your manual. Page 497 of of 557 shows the fuse panel.
2020 Hynundai Sante Fe Manual
Fuses to check that should be safe:
Never ever tap into Airbag, Safety Systems, Electronics or Modules.
ACC (Fuse that turns on when car is started)- RR SEAT (LH) 25ARear Seat Heater LH, Rear Seat Folding Switch LH <-- Test this fuse. Seems benign from what's listed.
Battery (Always on Fuse. Even when car is off) - P/SEAT(PASS)30APassenger Seat Manual Switch
Test those fuses with an LED light tester or Voltage Meter. LED light tester is easiest.
