chuckh007
Ok...how many have used the OBD socket to power source the B4K ? Well as it is the connection is simple, easy and works ...sort of ! The camera and the rear unit work very well with great images, however that is where it ends. Somehow the system needs a voltage modification or step down or ? to get the parking mode to function as advertised.If you set it up for motion detection or tilme lapse the thing works OK except it works in both scenarios (always on and ACC ) with no distinction for emergencies. In fact the G force barely works even in "high" level. Now if you want filming for short periods and don't mind searching the clips for what you want then the system is great. The imagery is really good but forget about "buffered" parking mode. Is there a solution to this without resorting to hard wiring the thing.
