Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- Umpteen
does this powerbank support pass through charging?
No.
Can someone with the manual provide the operating and storage temperature ranges?
Yes, extreme temperature for charging a lithium battery is anything below 0C or above 40C, probably not what most people consider extreme.The welcome guide just says "Avoid extreme temperatures"
Not very helpful.
Sent from my SM-G903F using Tapatalk
Not very helpful.
Hopefully it has a charging cut-out for outside that temperature range so that it is still safe?
Discharge temperatures are normally OK from -40C to 60C. (internal temperature of the cells.)
LiFePO4 typically should be kept between 0 and 40c. Charging below 0c can damage the cells. The cells will perform better up to 50c but will reduce their total charge / discharge cycles. They shouldn't be stored over 60c.
All in all LiFePO4 batteries are a much better bet than LiCoO2 batteries in hotter environments. They are more tolerant of higher temperatures and even work more efficiently as the temperature rises.
It's probably not a wise idea to leave the TQKA baking in a hot car for really extended periods of time but it would be a better option than using a typical lithium-ion battery bank. While elevated storage temperature shortens the service life of ALL lithium-ion batteries Li-phosphate will be far less susceptible to thermal runaway.
LiFePO4 car starter batteries are now on the market which indicates that at least some LiFePO4 can handle extreme environments. These batteries and LiFePO4 in general are "said" to operate safely at internal temperatures up to 65ºC that doesn't mean you can leave the TQKA running in your car at that temperature.
http://batteryuniversity.com/index.php/learn/article/types_of_lithium_ion
Hi guys. I read this entire thread. Still a bit confused. Do you have to press the battery banks each time you get in the car to wake them up or do they stay running and providing power to the cameras at all times (given it does not run dead)? The reviews report that the TQKA does not have pass through charging which doesnt work for my needs.
I can't see the point of buying my $170 dual dash cam and then spending $350+ on a cell link or blackvue battery bank.
Why can't we simply use a LifePO4 battery back, with pass through charging? So the battery bank charges on my 1 hr drive and supplies parking mode power to my camera while parked? I just did a test with my $30 10,000mAh Anker battery pack (understand not safe for the heat of the car) and it ran my dual cameras all night and will automatically start charging when I start my car's engine. Now, do they make anything like this with LifePO4 cells that is not $200+? Will they provide power without having to press the button on them ?
So has anyone figured out a seamless way to integrate this into their dashcam setup for parking mode function?
more than fair I think, good resultThey responded by offering me a refund of 50% of my original purchase price. Considering that the unit is 18 months old and the warranty had "technically" expired I thought that was pretty reasonable, especially since my original purchase price was $22.00 USD a year and a half ago and it now sells for $16.00. So, I immediately ordered a new TQKA to replace the failed one and I'm back in business with a brand new unit for a mere $5 bucks. I'd say I received pretty good customer service.
I was wondering now the US Amazon website has another version of the powerbank than earlier discussed in this thread: https://www.amazon.com/gp/B07CBQQ16V. In this current version there are some changes like added type C-port and USB out layout, but they don't mention anything about the heat, vibration and impact. Very eager to know before pulling a trigger if it's worth buying to power up a119 using in various temperatures. How different this version can be?
As a matter of fact I was able to purchase a LiFePO4 https://www.amazon.com/gp/B073QQPKVY. I'm not sure if I'll be able to cancel the order, if not I can send back anytime.Be aware that the TQKA power bank in the link you provided is NOT a LiFePO4 cell bank like the one discussed in this thread. It is uses lithium-polymer cells.
For the time being, I would suggest avoiding any TQKA power banks as they appear to have signifigant problems. I believe this is the reason that the TQKA LiFePO4 power bank that is the topic of this thread is no longer offered for sale and has not been for some time now. When I have some more time I will elaborate.
The first result the search throws is https://dashcamtalk.com/forum/threads/tqka-vs-cellink.39452/ this is the reason I decided to get the TQKA. I'm looking for something robust, but less expensive than Cellink to replace my current Aibocn 8000mAh.
I would love to know if the forum members discovered an alternative to Cellink availabe in the US market and not as expensive.
