- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
Happy New Year!
After several X2 firmware test updates in the private PowerUCC beta section, it's time to bring the latest stable version to the public. The X2 firmware is still evolving so even more is to come.
This version now has native exFAT formatting support for microSDXC
(meaning larger 64GB/128GB/256GB cards work great)
You can format these large cards inside the camera and you're good to go. In the past you had to manually format >32GB cards FAT32 on a computer. This is no longer needed thanks to the outstanding engineering team efforts. This new exFAT support has been added to all Panorama products across the board.
Panorama X2 firmware version: 1.01.09
-exFAT large memory card support, and over all writing stability across all brand memory cards improved.
(even SanDisk!)
-Driving Mode to Parking Mode bug fixed
-Added new High/Medium/Low brightness control & high/low bitrate per camera
-Added file allocation size per normal/event/parking
-Added LED on/off option (front blinking orange LED while recording)
-((Pending Edit, I'm sure I forgot a couple things))
-Grey Box popup/write error problem resolved. (exFAT related)
_________________________________
UPDATE:
1) Download:
https://www.dropbox.com/s/24kvft3wygsevhs/DHD_FullBurn.ELF?dl=1
2) Copy "DHD_FullBurn.ELF" to the root of each microSD card. (meaning not inside any folders)
3) Insert the microSD cards into your Panorama X2
(Important, your vehicle's engine must be running to ensure power is stable! Do not perform the update with the engine off)
4) Navigate via your easy to use touch screen to settings, about, and press update!
5) Watch the progress bar fill up, when it's done it will shutdown/reboot.
6) You will need to change the language back to English using visual icons alone since it will be in Korean
Below is step-by-step video on how to update a firmware on Panorama X2. (thanks @niko)
Note: This video was created before the latest exFAT support. You'll notice this video asks you to format the cards in the computer first. After 1.01.09 or above, there is no need to format cards in your computer any more. Just follow the video example so you know what to look for using the steps above.
Now that this herculean brain power effort of exFAT engineering has been completed, we can focus on improving the basic IQ/PQ into 2015. Way to go @Sungmoon Jang !
![oMPljQil.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FoMPljQil.jpg&hash=e03589f5332b59fc4ede94ca9eeab7c9)
(even SanDisk!)
![QlboZeI.png](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FQlboZeI.png&hash=772892f06535212df096da49a34da80b)
UPDATE:
1) Download:
