Ino
- Mar 21, 2014
- Australia
- Panorama II
Hey guys,
Just another report about a "work around" getting a 64G Samsung card to work. I've tried *EVERYTHING* - and I mean everything:
1). new firmware (from a 2G card - works perfectly)
2). partition the 64G card so it shows 4G, 16G, 32G
3). primary or extended partitions
4). FAT32, EXTFAT, No format.
5). Wipe the first 5G of the card (via dd if=/dev/zero of=/dev/diskX - on OSX) and repartition.
6). HP USB formatter, the above tools, the XDA "work around"
7). Windows format (funnily enough - FAT32/EXTFAT kept failing for partitions larger than 4G!!)
8). OSX format
None of these worked. The 2G card worked fine every time.
In desperation - I popped the card into my Panasonic TV and tried to recognise it there: lo' and behold I got the "I have not idea what *THAT* is"
OK, I said, TV - you format the bastard! (I was half expecting for it to fail formatting it - after all - WinXP kept failing successfully to do a simple task it should perform natively!)
30 seconds later - HEY! Presto! We have liftage! And the recognise function says "Yep, it's a SDXC, 61GB Formatted card"
Pop it into the dash camera: UTTER SUCCESS!!![Stick out tongue :p :p](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
So, try to format your card in your TV - that might do it!
If that fails - format it in your microwave - 2 minutes on high should do just fine! ![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
PS: If I can ever be arsed about it I would look to see what the difference is in format. Precisely - why the TV managed to format it successfully and a blasted WinXP failed (equally successfully). My hunch would be that there's something left on MBR and partition table sectors which doesn't make sense to a simple device like the camera, but which is ignored by the "higher IQ" devices (like PCs and so on.)
PPS: I was using winXP out of a VMWare virtual box on my Mac. This should make absolutely 0 difference. The laptop at work (native Win7) failed equally miserably!
8). OSX format
