GPak
The River 3 is currently on sale at Amazon for $159
If I get the River 3, all I need to do is buy a 15V USB-C, and I'll be set?
Welcome to DCT!or RIVER 2 will be better ?
In short, both the River2 and River3 are good options.
However, based on the information available online, I am leaning towards the Ecoflow River3 (R3) for the following:
-The R3 has the setting in the App to keep the 12VDC-Out port On as long as R3 is On, but most importantly, it remembers this settings next time R3 is On after shut-off.
This allows to use 12VDC-Out to be used to power dashcam without the need for a USB-C to 12VDC Cable, like for the R2.
EDIT: Providing the R3 goes into sleep mode with 12VDC port enabled but with no power draw by dashcam
-It has energy capacity of 245Wh or about 4% less than the R2, but it is advertised to be much more efficient, with low power equipment like the dashcam. This is true on the AC side, and I hope is somewhat true for the DC side as well.
-The USB-C port on the R3 is for output only and cannot be used for charging, but I prefer 12VDC charging anyway, because from the App I can adjust charging current to 4A, 6A or 8A, which corresponds to 50W, 75W, or 100W charging rate, respectively, as needed.
